Strange! You might want to check in Fiddler what's going on underwater, if there is any server communication at all there might be an error or invalid data somewhere that is being surpressed.
Also make sure to check the umbracoLog table and the Windows Event Log for errors.
Problem deleting node with IE7 [4.0.2.1]
Hiya all,
I am currently having problems deleting a node in IE7 with Umbraco 4.0.2.1
I get a JS error which is as follows:
Line: 432
Char: 13
Error: 'umbraco' is undefined
Code: 0
URL: http://ourinstall.co.uk/umbraco/umbraco.aspx
This was tested on Windows7 via XP Mode.
Firefox and IE8 work as expected.
I would appreciate any input on how to fix this please.
Many Thanks,
Warren
The node probably has an ' in it's title? I've seen this problem before, I forgot to report it as a bug actually.
No Sebastiaan the title is "delete me article" so no strange characters are in there.
Warren
Is it just this one node? Can you delete others?
Are you behind a proxy or firewall that might be doing javascript filtering?
No firewall or anything like that, and no i cant delete any nodes.
